CRV 97 - Problem with parking lights
Old Jan 5, 2009 | 07:20 AM
Faro's Avatar
Default CRV 97 - Problem with parking lights
My front parking lights don't work and it's not the bulbs and I can't see any blown fuse.
The rear parking lights work - so that would lead me to believe it's not the internal switch?
I'm inclined to think it might be a relay but I don't know which or where it is etc.
I don't really want to pay an auto-electrician. I was hoping first to try and re-place a relay and see if that does the trick. I guess they are not too expensive.
So any help in telling me where the relay is and identifying it would be appreciated or if anyone has any other ideas etc as to what the problem might be.
Any help or advice greatly appreciated.
Old Jan 5, 2009 | 03:59 PM
Default RE: CRV 97 - Problem with parking lights
since you have proven the bulbs to be good, and the fuse is good, have you checked to see if the ground is good, and then trace the front wire back to the fuse or known good power line. sometimes the plug at the fire wall is loose or a pin has backed out.
mike0094
Jun 1, 2009 08:05 PM
austin101385
Jun 19, 2007 02:50 AM
syeldell
Apr 12, 2007 03:11 PM
marky4
Oct 13, 2006 08:24 PM
