Cutting out sparaticly
Old Aug 12, 2006 | 05:31 PM
bblair's Avatar
Default Cutting out sparaticly
Hey guys,
My parents have a 1992 civic and its having some problems. It seems to cut out really irregulary............ it often cuts out when put under load but also when its rolling under low rpm. I havent got a chance to look at it myself but i figure its either the fuel pump or a loose connection to the fuel pump. They tried switching the main relay (apparently thats a problem for that year) but no lucK. Im going to pull the Spark plugs tonight and see what they look like but i figured id give this forum a try first.... just thought that someone else might have had the same problem.
Hope u guys can help
cheers
Old Aug 18, 2006 | 12:43 PM
tarheel1's Avatar
Default RE: Cutting out sparaticly
had this problem on a Fiat once and I replaced the electrical line to the fuel pump and it fixed it. Don't know if this helps.
t-roy
Dec 9, 2013 03:33 PM
awesomehog
Jun 9, 2010 11:33 PM
chunk0806
Feb 25, 2010 06:22 PM
wheelguyz
Aug 11, 2006 06:01 PM
04 mo neon
Aug 10, 2006 05:11 PM
