Del sol turbo kits??
Old 04-15-2007 | 05:01 PM
delsol10's Avatar
Default Del sol turbo kits??
i have looked at some sites to find some turbo kits for my 1995 del sol 1.5 and i cant find any kits that are ment for my engine. if anyone can tell me where i can find a good site for the correct engine that would be very helpful. thanks!
Old 04-16-2007 | 01:51 AM
67l60's Avatar
Default RE: Del sol turbo kits??
turbo a 1.8 or a 2.0 L vtec s**wthe 1.5 total waste of time
Old 04-16-2007 | 03:29 AM
delsol10's Avatar
Why is it a waste of time???
Old 04-16-2007 | 04:13 PM
67l60's Avatar
the 1.5 engine was meant for low power great fuel and the cost to turbo is the same if not more ,
with the end result being slower than the others
the b18 revs hard and will pull great with a turbo were the 1.5 will just rev hard and pull snot . unless you spend 10 k and youll still be slower than a all motor 2.2 l thats been tuned nothing replaces cubic inches so id start there and build a bigger motor and slap it in the del plus the parts are every where for the bigger motors and can be found cheaply
Old 04-17-2007 | 07:54 PM
delsol10's Avatar
well thanks for the advice, but im still sticking with the 1.5, i just wanna know where i can get a turbo kit that will match up for it, or will the 1.6 kit work for it???
Old 04-18-2007 | 09:28 AM
Noah automotive specialties.com, ( Greddy turbo ) Turbo-kit.com mimousa.com Do your homework and check them out before buying anything. Also going to the junkyard and viewing some of the stock turbo's on cars might help. Only turbos I've worked with are Garrett and Ray Jay's. On small airplanes. spooled motor sports is another site to view
Old 04-18-2007 | 07:24 PM
delsol10's Avatar
great, hey thanks alot man, i couldnt really find any site for my engine
Old 12-21-2013 | 01:34 AM
mackvallyk1k2's Avatar
Hi....
welcome to the site, here u can find lots of things , you can also just remove it and soak it in degreaser or dish soap for a day then clean it further. or there could be a crack or leak somewhere in the plastic tubing these tubes get extremely brittle after a couple years i had to replace them in my 2004 civic. or it could be the pump itself. or it could be a clog in the lines or in the and clean the reservoir, ither a disconnect in the wiring somewhere, faulty motor or clogged clogged pump outlet in the washer motor. Get near the driver fender and have someone hold the washer down and listen for the noise from the pump. If you don't hear anything then you'll need to test the pump by disconnecting it and applying 12V to the noI suggested u for your problem , you have contant here.
Automobile
bilder518
08-14-2010 09:07 PM
srtdriven7
03-26-2007 12:38 AM
Turborevs
09-10-2006 06:12 AM
Sexililsol
08-22-2006 02:15 PM
ones102envy
12-23-2005 03:43 PM
