Del sol turbo kits??
Old Apr 15, 2007 | 04:01 PM
delsol10's Avatar
Default Del sol turbo kits??
i have looked at some sites to find some turbo kits for my 1995 del sol 1.5 and i cant find any kits that are ment for my engine. if anyone can tell me where i can find a good site for the correct engine that would be very helpful. thanks!
Old Apr 16, 2007 | 12:51 AM
67l60's Avatar
Default RE: Del sol turbo kits??
turbo a 1.8 or a 2.0 L vtec s**wthe 1.5 total waste of time
Old Apr 16, 2007 | 02:29 AM
delsol10's Avatar
Why is it a waste of time???
Old Apr 16, 2007 | 03:13 PM
67l60's Avatar
the 1.5 engine was meant for low power great fuel and the cost to turbo is the same if not more ,
with the end result being slower than the others
the b18 revs hard and will pull great with a turbo were the 1.5 will just rev hard and pull snot . unless you spend 10 k and youll still be slower than a all motor 2.2 l thats been tuned nothing replaces cubic inches so id start there and build a bigger motor and slap it in the del plus the parts are every where for the bigger motors and can be found cheaply
Old Apr 17, 2007 | 06:54 PM
delsol10's Avatar
well thanks for the advice, but im still sticking with the 1.5, i just wanna know where i can get a turbo kit that will match up for it, or will the 1.6 kit work for it???
Old Apr 18, 2007 | 08:28 AM
Noah automotive specialties.com, ( Greddy turbo ) Turbo-kit.com mimousa.com Do your homework and check them out before buying anything. Also going to the junkyard and viewing some of the stock turbo's on cars might help. Only turbos I've worked with are Garrett and Ray Jay's. On small airplanes. spooled motor sports is another site to view
Old Apr 18, 2007 | 06:24 PM
delsol10's Avatar
great, hey thanks alot man, i couldnt really find any site for my engine
Old Dec 21, 2013 | 12:34 AM
mackvallyk1k2's Avatar
Hi....
welcome to the site, here u can find lots of things , you can also just remove it and soak it in degreaser or dish soap for a day then clean it further. or there could be a crack or leak somewhere in the plastic tubing these tubes get extremely brittle after a couple years i had to replace them in my 2004 civic. or it could be the pump itself. or it could be a clog in the lines or in the and clean the reservoir, ither a disconnect in the wiring somewhere, faulty motor or clogged clogged pump outlet in the washer motor. Get near the driver fender and have someone hold the washer down and listen for the noise from the pump. If you don't hear anything then you'll need to test the pump by disconnecting it and applying 12V to the noI suggested u for your problem , you have contant here.
Automobile
bilder518
Aug 14, 2010 08:07 PM
srtdriven7
Mar 25, 2007 11:38 PM
Turborevs
Sep 10, 2006 05:12 AM
Sexililsol
Aug 22, 2006 01:15 PM
ones102envy
Dec 23, 2005 02:43 PM
