EGR code
My wife's 2000 Accord with 2.3L just kicked up a check engine light for the EGR (she took it to the Honda dealer to read the code). They told her it needs the EGR port cleaned, and maybe a new valve installed. They want 200 in parts, and 480 in labor to do the job. How hard/bad is it to clean the port? Is this a pull the intake manifold and the valve off, and "roto rooter" it? Or is there more stuff involved going on that I'm not seeing? The dealership says it's most of a day job.
Thanks for any insight you can offer. |
if you get yourself honda accord service manual, it will show you how to clean a egr valve. it goes into the exhaust sys, no intake.
Originally Posted by acmech52
(Post 26797)
Originally Posted by Bob2000
(Post 26801)
I do have the factory service manual, and it DOES show the valve being bolted onto the intake manifold (located between the FPR and the thermostat housing). The book explains testing the valve electrically, and replacing it, but nothing on cleaning out the ports. This is why I asked how hard/bad of a job it is. I'm guessing the exhaust side of the port must be off #4 cylinder (since the valve is located on that end of the intake manifold), and run thru the head (probably under the cam) and to the intake manifold port that the valve is dumping into. It is an Exhaust Gas Recirculation valve after all. In the past I've just replaced the valve, not cleaned out the port, as it's never been a port being clogged issue.
Well done, Bob2000! You saved yourself some cash and took care of some much needed maintenance, too.
Gotta love a Honda! |
Originally Posted by cueball21
(Post 26875)
