Electrical Nightmare? Help!
Old Jul 16, 2011 | 12:54 AM
kornfox's Avatar
Member
Default Electrical Nightmare? Help!
I own a 1997 Honda Accord LX Coupe (2.2 Non-Vtec, Automatic). Recently, my door locks and drivers side power window quit working. If memory serves me correctly, the power locks failed first and window failed within days. When I use the aftermarket clifford remote to arm my alarm, the door locks do not engage as they previously had. I havent noticed even a noise that would suggest power to the actuators. If I attempt to use the interior power lock switches, I see the same result. This is the case for either door..
Within days, my drivers side power window refused to function. Whenever I try to use the window switch, I hear no attempt at motion nor motor activity. The drivers side switches will not operate either window, however, the passenger window control still allows the passenger window to function. If I engage the window lock mechanism on the drivers side, it does lock out controls for the passenger window. In maybe an unrelated failure, I can only manually lock the drivers door if I pull on the interior door handle prior to pressing the lock.
The drivers side mirror controls still function perfectly. I have checked literally every fuse in the car; both under the hood and near the dead pedal. Anyone have any suggestions on what the culprit could be? It seems strange that these failures would occur simultaneously.
Old Jul 18, 2011 | 09:16 AM
First pull the switches and test for power with a volt meter and make sure the connections were tight,If you have power the switch is bad.
pia
Dec 19, 2012 07:19 PM
kfrese
Jul 14, 2011 12:15 PM
Cain951
Nov 6, 2008 07:11 PM
Fire
Jul 22, 2006 07:26 PM
klholder
Jun 30, 2006 11:33 AM
