Element electrical system suddenly dead
Old Jun 26, 2012 | 07:25 PM
Mfsmith's Avatar
Default Element electrical system suddenly dead
Hi Forum,
We have an 06 Element 5 speed manual 55,000 miles. Today my wife drove it downtown, started and ran perfectly. Drove home, an hour later she tried to start it again....nothing. No keyless entry no nada zilch. I hooked up a battery charge and the gauge showed fully charged. I turned the charger to quick start, no engine turnover when I hit the ignition?
I looked at the 100 amp battey fuse in the engine compartment, looks good. Has anyone had this happen to them?
Thanks,
MFS
Old Jun 27, 2012 | 11:28 AM
Welcome to the forum,Check your headlights, if they come on bright This means the battery has 12 volts or so but it does not tell us if the battery is capable of providing the amps necessary to turn the starter over.
If they are dim or out quickly touch each battery cable connection at the battery. If either one is warm to the touch, that indicates a bad connection. Wiggle, push and pull the battery cables back and forth and see if the headlights come on white and bright. If the headlights come back on and as you hold the cable to one side or another, have someone try and start the car. More than likely, it will start.
If the starter is bad and you hit it with a hammer a couple of times, the starter will almost always work and the engine will start.
Old Jun 28, 2012 | 01:59 PM
Mfsmith's Avatar
Thanks for the reply buckwheat,
I am out of town at this time, I'll try those checks when I return.
Regards,
MFS
Old Jul 2, 2012 | 07:34 AM
Good luck buddy!
Old Jul 4, 2012 | 11:15 AM
Mfsmith's Avatar
Default Element
Turned out to be a failed battery. Thanks for the tip buckwheat. I just found it hard to believe it would give no indication of going bad, then completely dead after one hour of being parked, nothing left on?
Anyway I installed a new Interstate battery yesterday, no more worries.
Thanks
MFS
Old Jul 5, 2012 | 07:21 AM
Most likely a bad cell,I have two batteries on my F-350 Diesel and when one goes bad you have to replace both or the old battery draws from the new and causes problems.
GoldGal
Aug 30, 2014 11:26 PM
ackawily
May 16, 2014 08:08 PM
jinpdx
Mar 1, 2013 12:54 AM
simprince
Apr 9, 2011 10:44 PM
mikein21061
Nov 10, 2008 08:57 PM
