fan blower #1,2 not working 3,4 ok why?
Old Jul 18, 2006 | 06:39 PM
palomino's Avatar
Default fan blower #1,2 not working 3,4 ok why?
Hello,
Can anyone tell me why speeds 1,2 are not working but 3,4 do I have a Honda Accord SE 2002.
Thank you
Old Aug 29, 2006 | 12:55 PM
golfer's Avatar
Default RE: fan blower #1,2 not working 3,4 ok why?
It's likely the voltage control circuit for the blower motor that's faulty, there may also be two fuses for the blower.
Simply the blower is a 12volt motor and if on position #4 ( fastest ) the motor may be getting the full 12 volts.
On position #3 the motor may only need 10 volts to achieve desired speed , on position #2 may only require 7.5 volts for the desired speed and position #1 may only need 6 volts for the required speed.
You can check for voltage at the blower in position #1 & #2 but don't use a test light use a voltmeter ( multimeter ).
Old Sep 15, 2006 | 12:55 AM
topcivic1995's Avatar
maybe your resistors might be bad might have to replace them check.....
Old Nov 16, 2006 | 04:40 PM
cpatd's Avatar
I had an issue with the fan on my 99 EX V6 not working. It turns out that the resistor for the motor controls went bad. Honda replaced it for about $140.00
Old Nov 29, 2006 | 07:01 PM
Benniehonda's Avatar
sounds to me like a bad blower motor resistor or fan speed switch
Old Feb 24, 2008 | 11:23 PM
Vtech94CR's Avatar
I have a 94' civic ex and my blower motor is shot, how do i go about taking it out along with putting a new one in?
thanks,
Old Sep 28, 2009 | 09:34 PM
masduud's Avatar
Default blower motor resistor
I also have a 2002 accord se with same problem (AC and heat on work on settings 3 and 4, but not on 1 and 2). I took it to midas and they checked it an said the blower motor resistor needs to be replaced. They said the part costs $200 and the total would be $300. I did some research online and found that you can fix it yourelf. The blower motor is under the glove compartment on the passenger side, but the pictures were from a 98 accord. Does anyone know if the blower motor is in the same location for the 02 accord? I found a new blower motor resister much cheaper on ebay.
jah
Jan 25, 2011 09:29 AM
sdharwar
Apr 22, 2009 05:50 AM
Brentwoodupser
Jan 22, 2009 11:41 AM
stevel
Jun 28, 2008 09:48 AM
mykool
Nov 29, 2007 12:37 AM
