Foreign object in transmission
Old Aug 12, 2014 | 02:07 PM
Arvid McFly's Avatar
Default Foreign object in transmission
Recently after doing a drain and fill of the ATF in my 2010 Odyssey, the extension tip tube of my funnel came off inside the fill hole, and dropped down I tried to get it out, of course, but no luck. Can't see it or feel it with my finger or a wire. The piece is about 3 inches long, clear, soft plastic/vinyl, ~7/16ths diameter. After reading of some similar experiences ( lid caps, funnel ends) that don't sound like they ended in disaster by leaving them in, I have decided to leave it for now and see how it goes. I have put on about 100 miles hiway and town driving since, no apparent problems. I plan to do another drain and fill tonight, just to see what if anything comes out with the fluid, but then I guess I will leave it and hope for the best. Any thoughts or suggestions ( I mean besides the obvious of not being such a moron next time....)?
Old Aug 13, 2014 | 04:42 PM
lowlife9's Avatar
it could potentially clog the filter hindering oil pressure causing transmission damage. draining won't accomplish anything since it can't bypass the filter.
Old Aug 13, 2014 | 05:20 PM
Thanks for the reply. That makes scary sense to me. How much is involved with gaining access to the area? Is it a huge job to get at, or could a transmission shop get in there relatively easily?
Old Aug 19, 2014 | 06:14 PM
lowlife9's Avatar
im not familiar with honda mini vans but im guessing a shop with a lift and proper tools could easily gain access but its not going to be cheap cheaper then replacing the transmission though.
Old Nov 1, 2014 | 07:32 AM
Sxandy's Avatar
3rd pressure swith in tranny is bad p730 code- Trans shift malfunction,could be anything from a bad valvebody to dirty fluid.
__________________
