fuel injecters
Old Mar 21, 2007 | 04:00 PM
hondafied's Avatar
Default fuel injecters
how the *%$#@#@ do i unplug the wires to the fuel injecters. I am in the process of pulling the head off of my 95 civic dx. The gasket is bad (at least I hope it is the gasket not a crack) and I am spewing huge volumes of white smoke out of the tail pipe and the radiator went empty. the oil doesnt look foamy or anything thankfully. The books that i have only say "disconnect the fuel injector wires". Usually the connectors on cars have a locking tab but these do not.
Old Mar 22, 2007 | 10:59 AM
Default RE: fuel injecters
Aloha hondafied, go to autozone.com, you can register for free if you like, and go to repair after entering your year and make of vehicle. It will take you to fuel injectors and show you a picture in black and white using a pick to release the spring clip to remove the plug on the injector. Hope this helps
Old Mar 22, 2007 | 03:04 PM
hondafied's Avatar
WOW Thanx a lot acmech52. I was starting to get frustrated there. Have a great day
lp284
Nov 8, 2010 12:36 AM
