help please.. my 90 accord tachometer and speedometer stuck
Old Sep 15, 2007 | 11:51 PM
pandong's Avatar
Default help please.. my 90 accord tachometer and speedometer stuck
hi. can you guys help me? my car won't start co'z the battery was really low in charge so i hooked up my car battery booster,then i turn on my ignition then both needle in my tachometer and speedometer turn 360 degrees and stop.so i started the car hoping it will the needle will return back to 0 but it didn't. pls help
Old Sep 20, 2007 | 10:06 PM
Dongss's Avatar
Default RE: help please.. my 90 accord tachometer and speedometer stuck
I think you may have connect the battery jumper cables in reverse....
Check your battery voltage, if's it's low, replace the battery after it's load tested at your local auto parts store. Battery can blown up if the cables are hooked up backwards.
If the car doesn't respond, check your main fuses - you may have blown some ecm's possibly from hooking up the jumper cables backwards.
Dongss
cherry70
Jul 29, 2008 02:36 PM
pandong
Dec 9, 2007 05:30 PM
pandong
Sep 15, 2007 03:27 PM
cosmo
Jul 31, 2006 11:15 PM
cosmo
Jul 25, 2006 12:25 AM
