Honda Civic 96’ no spark
Old Oct 13, 2018 | 02:58 PM
SantosZ33's Avatar
Default Honda Civic 96’ no spark
So my honda civic cranks but it’s not throwing spark and I’ve already replased the ignition coil, igniter, spark plug wires and spark plugs. I checked the main relay and it’s working. There’s power going through the distributor, so checked for pulse in the negative terminal of the ignition coil with a test light and the light didn’t blink. If someone can help or had the same problem and found a solution I would appreciate the help.
Old Oct 13, 2018 | 11:02 PM
Old Oct 13, 2018 | 11:03 PM
Old Oct 14, 2018 | 08:44 PM
SantosZ33's Avatar
Could it be the ignition switch on the steering column? I did all the tests on the videos and everything checks out, last thing I haven’t checked is the ignition switch.
Old Oct 14, 2018 | 10:42 PM
If everything checks out then it should be working.
I can not see what you are doing
Or how you are doing your tests
This is not to say you are doing anything wrong
But something must not be right
No, doubtful it is the ignition switch that is causing no spark ... since you need to use the switch to crank engine for most of the tests
johnhauck
Mar 25, 2016 08:01 PM
usmarine0905
Feb 20, 2013 09:04 AM
89hondacrx
Aug 31, 2010 04:20 PM
johnu773
Jun 26, 2008 10:51 PM
proff
Jun 25, 2008 05:09 AM
