Honda civic Engine light Code Help
Old Apr 14, 2007 | 03:34 AM
hondaAutomatic's Avatar
Default Honda civic Engine light Code Help
My automatic98 honda civic Engine light recently came onandI had it check out.The EngineCode read PO700-Transmission Control System (Mil Request) and PO715-Turbine/Input Shaft Speed Sensor Circuit. Recently my car have been experiencing acceleration hesitation. Anyways does anyone have any on how to repair these Engine code problem. Exactly where is the input shaft speed sensor or what other parts do I need to replace? Any help is would be appreciated.
Thanks,
Old Apr 14, 2007 | 04:24 AM
67l60's Avatar
Default RE: Honda civic Engine light Code Help
main shaft speed sensor is located right side of transaxle
its the sensor closest to the engine at about mid radiator
Old Apr 14, 2007 | 04:41 PM
How many speed sensors are there on the transmission? Is the main shaft speed sensor you are talking about located by them selenoids facing the radiators sides or is it behind and next to the transmission dip pole. Any examples on how the main shaft sensor? Not very farmiliar with the automotive terms.
Old Apr 16, 2007 | 12:48 AM
67l60's Avatar
in all theres about 5 speed sensors depending on the trans you have ebay has a manual for like 10 bucks its on cd with tons of pictures and test procedures with pictures
id start there and then try to DIY then at least we will have the same referance material to work frombutt the mainshaft sensor is behind the radiator closest to engine on the tranny
Old Apr 17, 2007 | 01:59 AM
Hey do you know what the manual book is called. Link me to the ebay site.
Old Apr 17, 2007 | 03:27 AM
67l60's Avatar
http://cgi.ebay.com/ebaymotors/96-20...QQcmdZViewItem
Old May 7, 2007 | 03:23 AM
Update on current situation. Went and bought the main shaft speed sensor and linear selenoid. Flush out the transmission fluid and fill in new ones. As a result, the car had more power once the car is in motion. Even the Engine light went out also. Then everything changed. The next day, engine light came back on with the same engine code problem and the car start experiencing the same hesitation during acceleration. As of now, the car also rolls back on hills eventhough the caris still on drive. Could it be that my auto transmission is screw or is it electrical problem? Need help!
cjang
Apr 17, 2024 06:29 PM
hokietiger
Apr 14, 2015 06:18 PM
Sikstikchik
Oct 26, 2012 09:45 AM
cmadonia
Apr 9, 2009 06:19 AM
papic03
Mar 6, 2007 09:17 PM
