Honda Fault Codes List
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1 P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1 P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1 P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2 P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2 P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1 P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1 P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1 P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM) P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM) P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2 P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2 P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2 P0068 - Throttle Body Airflow Performance (PCM) P0100 - MAF Sensor Circuit Insufficient Activity P0101 - Mass Air Flow (MAF) Sensor Performance P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency P0104 - Mass Air Flow Circuit Intermittent P0105 - MAP Sensor Circuit Insufficient Activity P0106 - Manifold Absolute Pressure (MAP) System Performance P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage P0109 - Manifold Absolute Pressure Circuit Intermittent P0110 - Intake Air Temperature (IAT) Sensor Circuit P0111 - Intake Air Temperature (IAT) Sensor Performance P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage P0114 - Intake Air Temperature Circuit Intermittent P0115 - Engine Coolant Temperature (ECT) Sensor Circuit P0116 - Engine Coolant Temperature (ECT) Sensor Performance P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage P0119 - Engine Coolant Temperature Circuit Intermittent P0120 - TP System Performance P0121 - TP Sensor Circuit Insufficient Activity P0122 - Throttle Position (TP) Sensor Circuit Low Voltage P0123 - Throttle Position (TP) Sensor Circuit High Voltage P0124 - Throttle Position Sensor 1 Circuit Intermittent P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control P0126 - Insufficient ECT for Stable Operation P0128 - Coolant Thermostat Below Thermostat Regulating Temperature P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1 P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1 P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1 P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1 P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2 P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2 P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2 P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2 P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2 P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3 P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3 P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3 P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3 P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3 P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1 P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1 P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1 P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1 P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1 P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1 P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2 P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2 P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2 P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2 P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2 P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2 P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3 P0169 - Fuel Composition Sensor P0170 - Fuel Trim Bank 1 P0171 - Fuel Trim System Lean Bank 1 P0172 - Fuel Trim System Rich Bank 1 P0173 - Fuel Trim Bank 2 P0174 - Fuel Trim System Lean Bank 2 P0175 - Fuel Trim System Rich Bank 2 P0176 - Fuel Composition Sensor Circuit P0177 - Fuel Composition Sensor Circuit Performance P0178 - Fuel Composition Sensor Circuit Low Voltage P0179 - Fuel Composition Sensor Circuit High Voltage P0180 - Fuel Temperature Sensor 1 Circuit P0181 - Fuel Temp. Sensor 1 Circuit Performance P0182 - Fuel Temperature Sensor Circuit Low Voltage P0183 - Fuel Temperature Sensor Circuit High Voltage P0184 - Fuel Temperature Sensor 1 Circuit Intermittent P0185 - Fuel Temperature Sensor 2 Circuit P0186 - Fuel Temp. Sensor 2 Circuit Performance P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage P0188 - Fuel Temperature Sensor 2 Circuit High Voltage P0189 - Fuel Temperature Sensor 2 Circuit Intermittent P0190 - Fuel Rail Pressure Sensor Circuit P0191 - Fuel Rail Pressure Sensor Circuit Performance P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage P0193 - Fuel Rail Pressure Sensor Circuit High Voltage P0194 - Fuel Rail Pressure Sensor Circuit Intermittent P0195 - Engine Oil Temperature Sensor P0196 - Engine Oil Temperature Sensor Performance P0197 - Engine Oil Temperature Sensor Low Voltage P0198 - Engine Oil Temperature Sensor High Voltage P0199 - Engine Oil Temperature Sensor Intermittent P0200 - Injector Control Circuit Full List HERE IS Honda Fault Codes - car manuals & wiring diagrams |
welcome to the forum. Thank you for the info igor2009.
