Honda Fault Codes List
Old May 1, 2016 | 05:05 AM
igor2009's Avatar
Default Honda Fault Codes List
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
P0101 - Mass Air Flow (MAF) Sensor Performance
P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency
P0104 - Mass Air Flow Circuit Intermittent
P0105 - MAP Sensor Circuit Insufficient Activity
P0106 - Manifold Absolute Pressure (MAP) System Performance
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0109 - Manifold Absolute Pressure Circuit Intermittent
P0110 - Intake Air Temperature (IAT) Sensor Circuit
P0111 - Intake Air Temperature (IAT) Sensor Performance
P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 - Intake Air Temperature Circuit Intermittent
P0115 - Engine Coolant Temperature (ECT) Sensor Circuit
P0116 - Engine Coolant Temperature (ECT) Sensor Performance
P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 - Engine Coolant Temperature Circuit Intermittent
P0120 - TP System Performance
P0121 - TP Sensor Circuit Insufficient Activity
P0122 - Throttle Position (TP) Sensor Circuit Low Voltage
P0123 - Throttle Position (TP) Sensor Circuit High Voltage
P0124 - Throttle Position Sensor 1 Circuit Intermittent
P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0126 - Insufficient ECT for Stable Operation
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature
P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2
P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2
P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3
P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3
P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3
P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response
P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3
P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3
P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1
P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2
P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2
P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2
P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3
P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage
P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage
P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response
P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected
P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3
P0169 - Fuel Composition Sensor
P0170 - Fuel Trim Bank 1
P0171 - Fuel Trim System Lean Bank 1
P0172 - Fuel Trim System Rich Bank 1
P0173 - Fuel Trim Bank 2
P0174 - Fuel Trim System Lean Bank 2
P0175 - Fuel Trim System Rich Bank 2
P0176 - Fuel Composition Sensor Circuit
P0177 - Fuel Composition Sensor Circuit Performance
P0178 - Fuel Composition Sensor Circuit Low Voltage
P0179 - Fuel Composition Sensor Circuit High Voltage
P0180 - Fuel Temperature Sensor 1 Circuit
P0181 - Fuel Temp. Sensor 1 Circuit Performance
P0182 - Fuel Temperature Sensor Circuit Low Voltage
P0183 - Fuel Temperature Sensor Circuit High Voltage
P0184 - Fuel Temperature Sensor 1 Circuit Intermittent
P0185 - Fuel Temperature Sensor 2 Circuit
P0186 - Fuel Temp. Sensor 2 Circuit Performance
P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage
P0188 - Fuel Temperature Sensor 2 Circuit High Voltage
P0189 - Fuel Temperature Sensor 2 Circuit Intermittent
P0190 - Fuel Rail Pressure Sensor Circuit
P0191 - Fuel Rail Pressure Sensor Circuit Performance
P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
P0193 - Fuel Rail Pressure Sensor Circuit High Voltage
P0194 - Fuel Rail Pressure Sensor Circuit Intermittent
P0195 - Engine Oil Temperature Sensor
P0196 - Engine Oil Temperature Sensor Performance
P0197 - Engine Oil Temperature Sensor Low Voltage
P0198 - Engine Oil Temperature Sensor High Voltage
P0199 - Engine Oil Temperature Sensor Intermittent
P0200 - Injector Control Circuit
Full List HERE IS Honda Fault Codes - car manuals & wiring diagrams
Old May 4, 2016 | 06:22 AM
welcome to the forum. Thank you for the info igor2009.
stryker24
Jul 20, 2011 05:35 AM
PostRelease
Jul 30, 2010 09:30 PM
jjmcox
Feb 15, 2010 09:01 AM
trev0006
Sep 16, 2009 03:34 PM
toytruck89
Dec 9, 2007 06:57 PM
