How to install a conversion HID kit?
Old Jan 14, 2013 | 03:39 AM
Forrest's Avatar
Default How to install a conversion HID kit?
Hi, guys. I recently bought the Slim hid conversion kit for my Accord 2001 . I tried to install them, but when I started my car, the lights started flashing. So comfused, if anyone could let me know what's going on with the kits?
Old Jan 14, 2013 | 07:36 AM
Blinking of HID lights (Blinking: The constant instantaneous switching on and off of the HID lights):
This is caused either by bad installation of the HID's (crossing negative and positive terminals, no proper grounding etc) or by defective ballasts/bulbs. This issue can be seen in both 35W or 55W HID's.
Read more: http://mbworld.org/forums/c-class-w2...#ixzz2HxNcZI8j
Old Jan 14, 2013 | 09:36 PM
lowlife9's Avatar
i strongly advise the use of a relay harness so you get power directly from the battery and not the stock wiring.
Old Jan 15, 2013 | 05:00 PM
I read that somewhere, makes total since.
Old Jan 16, 2013 | 01:23 AM
lowlife9's Avatar
HIDS use tremendous power on ignition, voltage the stock wires were never meant to handle. problems can occur ranging from flickering lights to fried wires sometimes even fire.
Old Jan 16, 2013 | 08:16 AM
Thumbs up
Good post!
Old Jun 26, 2013 | 11:05 PM
Den Rosales's Avatar
I had my HID installed but I never had flickering issues. Maybe there's malfunctioning part on any of the HID Parts. You may want to check that on your seller, otherwise you would need capacitors.
Old Jul 16, 2013 | 05:21 AM
Dorisscott's Avatar
Originally Posted by lowlife9
http://www.youtube.com/watch?v=3ZWRjt8UW8g i strongly advise the use of a relay harness so you get power directly from the battery and not the stock wiring.
Good stuff, This is a helpful post!
Old Jul 16, 2013 | 05:25 AM
Dorisscott's Avatar
Hey Forrest, I think the above video is helpful to you. If you still not getting it, then you use the voucher that usually comes with products, read out the instruction and I'm sure you will get it fix easily.
Old Jul 16, 2013 | 05:31 AM
  #10
GilbertF's Avatar
Member
Go here http://www.360tuners.com/hidconversionkits.aspx . You can find here the easy plug and play hid conversion kits. You need not to cut any wire.
jps honda
Oct 22, 2008 07:07 AM
hidhookup
May 19, 2008 12:31 PM
jmpeter1
Apr 5, 2007 05:32 PM
Dong
Mar 27, 2007 05:17 AM
ioohairballooi
May 10, 2006 02:45 PM
