i need help
Old Apr 29, 2010 | 03:58 PM
91haydenSI's Avatar
Default i need help
okay i know this is a honda forum but i have a problem not related with a honda and im hoping that Doug or someone reads this and gives me good feed back okay so i have a 1998 ford escort se wagon.. about 2 months ago it just died so i ran a code scanner on it and it said the EGR valve and the Camshaft Position Sensor was bad.. so i replaced the EGR valve and CPS... still the car would not crank.. in replacing the CPS i had to remove the fuel rail and injectors so i took that opportunity to make sure it was delivering fuel to the motor.. it was.. so i decided to check to see if it was getting spark.. it only got spark to cylinder 2.. i then replaced the coil pack, wires, and plugs... and yet the car still wont crank nor does it feel like it is getting spark... i feel this may be an ecu issue but i need to know a way to test it other than swapping in a new one and seeing if it cranks.. any help would be appreciated
Old May 5, 2010 | 05:30 AM
have you checked the the timing belt, may have skipped a tooth or worn out. if you have over 85-120k miles it may be possible. Sorry for the slow reply, I've got a new work schedule.
Old May 6, 2010 | 01:17 PM
91haydenSI's Avatar
yeah same here.. and i was hoping it wouldnt be the timing belt its going to suck to replace.. i have a bunch of new pictures of the honda i will be uploading soon im pretty excited hope all is well
okhozi
Jan 6, 2010 09:10 AM
90civicDX
Apr 1, 2009 09:32 AM
91hondaaccord
Jul 21, 2008 05:15 PM
