Idle issues
Old Dec 1, 2013 | 02:28 PM
TurboTonaVa's Avatar
Default Idle issues
working on a 94 civic. Has idle issues. Idle is running up and down. Not sure how to check for engine codes so I have none. Car has a breather pipe and cone filter .
Old Dec 1, 2013 | 08:30 PM
lowlife9's Avatar
first check for vacuum leaks then clean the IACV also remove the intake check and clean the throttle body its most likely filthy from the cheap ebay cone filter thats most likely on your car if so replace it ASAP with a filter that actually filters the air like AEM.
Old Dec 3, 2013 | 06:16 PM
I can only add to use throttle body cleaner not carb cleaner.
Dads_Honda
May 26, 2015 03:13 PM
5star
Oct 26, 2013 10:50 AM
wolfbone
Mar 12, 2011 07:47 PM
WIAccord
Nov 14, 2010 07:02 PM
96LxAccord
Mar 23, 2010 10:12 AM
