need help with a d16y8 swap
Old Feb 19, 2009 | 03:38 PM
teamhonda's Avatar
Default need help with a d16y8 swap
ok here it is i have a 1995 ex coupe and i threw a rod. i am swapping it out with a d16y7 with the y8 head. i need help on getting it 2 run.its gettin spark fuel and what not.but i am worried about the air bein blown out the intake manifold instead of bein sucked in can ne one help me with this issue thanks every one
Old Feb 19, 2009 | 10:05 PM
if you have air blowing out the intake, check your timing belt, and cam to crank timing. Also take a compression check to see if you might have open valves when they should be closed.
yogibear27804
Dec 1, 2013 07:12 AM
KreggLee
May 21, 2011 10:15 PM
rsmckee
Jun 19, 2009 02:00 PM
92civic1290
Oct 10, 2008 01:52 AM
Chaser886
Jul 23, 2006 04:32 AM
