New Car Broke Down Babied Idk What Happened
Hi guys new to hondas and honda fourm and as you all know i now have that itch. I jus bought my Ek and as i was riding in 5th gear bout 65mph felt slight hesitation then i went to accelerate and car bogged down shifted to 4th and same reaction so had to pull to side of highway i could start the car though it would take quite a few cranks to get it to start it would idle fine but the slightest touch of the gas the car would cut off. There were no bangs clunks clinks grinds nothing like that and im just stumped will be working on it next few days and will post any new progress any help from anyone would be greatly appreciated. Heres a complete breakdown list of everything on the car.
Engine: 1999 GSR motor + transmission -approx. 80,000 on motor 6puck clutch 8lb lightened flywheel ITR valve cover Crower Stage 2 cams AEM cam gears AEM pulley AEM fuel rail GSR Throttle Cable OEM Spark plug wire cover Innovative 75A Track Motor Mounts 3” DMH E-cutout with single Flowtech Flat black OEM Honda muffler Turbo Setup: Precision SC60 .63 hotside .60 compressor Compressor specs wheel diameter - 59mm wheel inducer - 2.320" exducer - 3" trim - .60 bearing system = 360 race A/R - .63 Turbine specs garret wheel style - T31 inducer - 2.559" exducer - 2.220" trim – 76 Stainless Steel Oil lines and flared fittings 10” A/C Slim Fan 12” Radiator Slim Fan Neukin AC Manifold Neukin AC 3” Downpipe Neukin Dump Tube Tial 44mm Polished Wastegate 0.3 bar 4.35 psi Spring Turboxs RFL Type-H Turboxs BOV Flange (4) NGK BKR7E gap .030 Walbro 255lph High Pressure Fuel Pump Golden Eagle Vacuum block and fittings AC Autotechnic Oil Block Adapter RC 550cc Saturated Injectors with clips Cyberdyne Red LED Vacuum/Boost Gauge AEM 6-1 UEGO Wideband Gauge 5-bolt Discharge gasket GM Boost Solenoid GM 3 bar Map Sensor with pigtail Dual Cluster Pod AEM EMS 1020 OBD2A Precision 600hp Intercooler |
RE: New Car Broke Down Babied Idk What Happened
i know this is kind of a lame answer, but check the condition of your fuel filter. It's amazing the difference a clean one can make.
| All times are GMT -5. The time now is 10:36 AM. |
