New to Honda... but a longtime love.
Old Mar 20, 2011 | 09:03 AM
DarrkTeddy's Avatar
Question New to Honda... but a longtime love.
Hey all.
I just got a 91 Civic DX; mostly stock with a decent and crappy homemade cold air intake. My cousin just gave the car to me. Basically he beat the crap out of it and then let it sit for 2 months with no radiator in it. He also gave me a set of coil-over springs for it as well.
So I got it home yesterday and got a radiator in today. I was having some problems getting it started so i pulled the plugs to see the head filled halfway full of oil where the plugs usually sit. I took them all out used some parts cleaner and cleaned everything up and she started up after a little convincing with starting fluid.
After all that, here's my question: what does it usually mean when there's that much oil sitting with those plugs? Valve cover seal? I'd appreciate any advice. Thanks.
Old Mar 23, 2011 | 02:47 PM
There is an O-ring that seals the spark plug well and keeps oil from leaking into it. As with any valve cover gasket, it will start to leak over time. Sometimes tightening the valve cover bolts will stop the leakage, but more often than not the valve cover gasket, and well seals, will need to be replaced.Good luck,Bobby
Old Mar 25, 2011 | 01:00 AM
jay98accordcoupe's Avatar
hey im having some shifting issues with my 98 accord coupe automatic can i get idea of problems ( shifts slushy from 1st to 2nd )
Old Mar 25, 2011 | 07:23 AM
Welcome to the forum ,you did not post the mileage on your trans,but just guessing you may have shift solenoids opening slowly,a trans fluid change may help,I know I had a problem where mine would shift into reverse very slowly and a flush cured the problem ,good luck,Bobby
Old Mar 26, 2011 | 08:46 PM
91haydenSI's Avatar
beware of that 91 civic.. i have 2 of them and they LOVE LOVE LOVE LOVE (etc) to have problems with the clutch assembly inside the cabin.. just check it every so often to make sure there is no play in the pedal arm other wise you will end up selling your Huevos to get the car fixed
Flyboy
Sep 23, 2015 02:03 AM
Chris McArthur
Nov 28, 2014 03:25 AM
porp
Mar 26, 2013 11:11 PM
magotte
Mar 12, 2013 10:15 PM
TheUnFit
Jul 13, 2009 01:20 PM
