No low end power
Old Jul 17, 2012 | 04:06 PM
wayne0's Avatar
Member
Default No low end power
My '94 Delsol SI (275K mi.) has NO low end power.
When i step on the gas after a stop it seems to just creep up to speed.
I can floor the pedal and it behaves the same. Gets scary when crossing busy traffic!
When I get up to about 25mph it starts to pick up rapidly.
No problem accelerating once I'm moving.
I've tried nothing yet.
Where should I start?
Old Jul 18, 2012 | 11:59 AM
You didn't say if auto or stick,If stick it could have a slipping clutch,replace your fuel filter if that doesen't help have your fuel pump checked.
Old Jul 19, 2012 | 01:04 AM
lowlife9's Avatar
when is the last time you did a tune up ???
Old Jul 19, 2012 | 05:01 AM
wayne0's Avatar
Member
I forgot to mention it only happens when the motor is hot. Auto trans. ( does not over rev when it happens) Fuel filter is new. Tune up about 15K ago.
Old Jul 19, 2012 | 07:44 AM
Sounds like a vapor restriction of some type,where the fuel is heated to the point of vaporization,check to see if a fuel line is close to an exhaust manifold maybe.
Old Jul 19, 2012 | 07:32 PM
wayne0's Avatar
Member
I'll check that out.
Went to replace rear pads tonight and on turning the left piston in, the dang thing started leaking. 2 calipers coming tomorrow. It's always something!
yogibear27804
Jan 28, 2015 05:34 PM
studebaker
Aug 26, 2012 08:48 PM
tomwegeng2000
Oct 14, 2009 02:51 AM
nelpasa
Mar 9, 2007 11:02 PM
zipzero666
Aug 29, 2006 01:27 AM
