No start, No Spark 92 Accord. Advice?
Hello everyone. I'm new to the site and I'm hoping someone can help me out.
I pulled the head on my 92 Accord EX to troubleshoot a rough idle. Found an exhaust valve with a hole in it and had it replaced. Reassembled the engine, replacing all the gaskets along the way and making sure all electrical connectors were reattached.
After reassembling the engine would not start. I checked and found that I had no spark. The ignition coil and igniter didn't pass the checks in my manual so I replaced the distributor and ignition coil tower. The wires are only a few months old, the spark plugs are brand new and the ignition coil receives battery voltage at its three pin connector. I suspect the main relay but I don't want to replace another expensive electrical/electronic component without asking someone else.
Thanks in advance.
Thanks in advance.
welcome to the forum. since your engine was dissasembled, check your timing belt to the proper marks on the cam and crank. also some distributors if aftermarket have problems from the overhaul shop. tend to use, used parts to overhaul.
can so one help? im in need of help.. im new to tha forum.. i have my 90 integra. And its turning over but still wont start.. i just got it from tha shop yesterday for and overhaul.. so its not tha engine, i have a feeling its my starter.. its sounding like it wants to come on but doesn't... HELP ME HF..
