oil leak please help im new to honda's
Old Jun 15, 2012 | 11:14 AM
countryboy4's Avatar
Default oil leak please help im new to honda's
first off i would like to say im caleb im 19 years old, im used to working on v8 small blocks and mud trucks i have a restored 1995 honda accord 4 door now and it was free from my sister because my restored 86 chevy 4x4 has been stolen so this car is being used to get me back and forth to college, work, etc it has a stock f22b2 motor, new water pump and timing belt new distributor, cap and button but it has a oil leak and im nervous about driving it because of it because i do not know if its major and i do not know where it is comming from ill post some pics tonight to give you guys an idea where it is comming from. its leaking on the driver side close to the cv axle and the axle is not leaking any ideas?
Old Jun 18, 2012 | 09:23 AM
Welcome to the forum,The best way is to clean the motor first, then check your oil filter to see if it's coming from there,oil leaks are hard to find when coming from up top of the motor,check the valve cover gasket and around the timing cover. How much oil and is it blowing back and onto you trunk area?
Old Jul 17, 2012 | 05:43 PM
wayne0's Avatar
Member
Default Oil leak
I had a semi major leak in my '94 Delsol. Oil dripping on my exaust etc. Turned out to be the valve cover gasket.
Old Jul 18, 2012 | 11:54 AM
That's common,in some cases you can retorque the bolts to spec. and not need a new gasket.
Timwilliams13
Sep 26, 2013 08:51 AM
PHC
Jul 15, 2013 02:29 PM
kbrook1218
May 27, 2013 05:21 PM
dj00140
Mar 19, 2010 10:27 AM
XHONDAX
Sep 17, 2006 09:31 PM
