oil level
Old Jul 26, 2015 | 09:26 PM
anon125's Avatar
Default oil level
our 1997 Honda crv manual reads that you should not have the oil level above the second mark.
we get the oil change at a Honda dealer.
after a few days of non use when I check the level it is always above the top hole.
ideas anyone?
thanks
Old Jul 27, 2015 | 04:25 PM
brags's Avatar
If its a tad over its not a big deal but if it looks like a bottle
has been added then definatly should be drained out too much oil
is not good for seals and gaskets on an engine.
Old Jul 29, 2015 | 07:30 PM
lowlife9's Avatar
it needs to be directly on the second hole beyond that is too much this is the reason i do my own oil changes. considering how much the dealer charges for an oil change you would think they'd take the extra step to do things correctly. i would expect that from a quick lube business not a honda dealer but i quess it ultimately comes down to the individual person performing the oil change. i guess thats what you can expect considering they usually give that job to the trainees. even so if they screwed that simple job up what else did they screw up the oil filter or maybe the drain plug ???
Old Jul 31, 2015 | 01:22 AM
Just a heads up. Oil creeps up the dipstick as it sits a long while. Oil should be checked after a short run.
Old Oct 8, 2015 | 02:28 PM
anon125's Avatar
does this look like over filling or creep?
car last outing was yesterday.
should we wipe it off and then test again?
thanks
Old Oct 8, 2015 | 03:33 PM
anon125's Avatar
we wiped it off, still the ame
Old Oct 9, 2015 | 07:35 AM
The oil level a little over the 2nd hole is not much, if you're in doubt, take it to the dealer and they will say the same, if not they will drain a bit out. Since they serviced the vehicle.
Old Oct 9, 2015 | 06:54 PM
anon125's Avatar
Thanks
Old Oct 9, 2015 | 07:04 PM
lowlife9's Avatar
thats to much i would loosen the drain plug and let a little out. overfilling can be just as bad as underfilling.
Old Oct 10, 2015 | 07:48 AM
  #10
anon125's Avatar
thanks
it goes to the dealer next week for oil change anyway.
we will show them the pick.
