oil from valve cover on b18c
Old Jan 30, 2014 | 10:25 PM
ronoc17's Avatar
Default oil from valve cover on b18c
hi guys the other day i was driving, (normal all day, no high revs until now) and i floored it off a light, my red line is 8250 and i brought it up to 8, then when i shifted my car jerked 4 times and now when i start my car the revs bounces from 100-1200 right away for ab out 5 seconds then go back to normal, and now when i look under my hood i find this oil, im not sure the problem with my motor can anyone help?
Old Jan 31, 2014 | 06:01 AM
welcome to the forum. need to clean old oil off the cover than recheck for oil leak. may be the cam end cap o ring leaking. not sure on revs bouncing, has the engine gone back to normal running.
Old Feb 1, 2014 | 05:01 PM
Welcome in,try to tighten any loose bolts,clean engine and check again for the leak. The revving could be a vacuum leak or the Idle Air Control.
m.e.greene
Aug 24, 2019 01:36 PM
ndrew2505
Nov 2, 2008 07:45 PM
bettystech
Jan 22, 2008 04:39 AM
Dominus
Oct 30, 2007 08:40 PM
SCCinc
Oct 8, 2007 03:53 PM
