Please help!
Old Jun 12, 2012 | 08:45 PM
deezbs's Avatar
Exclamation Please help!
I recently removed the manifold heat shield(96' f22b1) because it looked awful and it was rattling. To combat the extra heat, i removed the manifold and used a ceramic paint on it. Didn't help much. When i reinstalled the exhaust manifold i used some nuts i found at lowe's that i thought were close enough to the same as the honda locking nuts (probably stupid). Anyways, im trying to get it out again so i can put MANY layers of ceramic on it, but there is one nut i can not get off. It spins and spins but doesn't move. I bought a nut splitter at the hardware store but the way it's set up i can't get it to bite the whole nut. I've tried cutting it with dremel tools and all kinds of other stuff. I've literally been fighting this thing for a day and a half. I feel like i've tried everything. I'm afraid of damaging the stud. There's hardly anything left of the nut but its enough to keep my from removing the manifold. Is there a trick i don't know about besides not using non automotive parts on a Honda?
Old Jun 12, 2012 | 11:25 PM
lowlife9's Avatar
i would just keep at it with the dremmal. and that store bought rattle can paint sucks the only paint that will help is jet coat otherwise i would use header wrap or thermal jackets but honestly removing the heat shield really won't harm anything. i use a race header without a heat shield and with a carbon fiber hood and i have had zero issues.
Old Jun 13, 2012 | 02:23 PM
I second the Jet coat,the only problem I ever had with a heat shield was heat soak on a starter many years ago,but that wouldn't apply to your Honda,I would try one thing first before cutting ,try prying up on the nut as you turn it with a pry bar maybe.That may put enough pressure on it to move it and shoot it with pb blaster and let it soak.
okhozi
Jan 6, 2010 09:10 AM
nathancrowder
Oct 23, 2008 12:28 AM
91hondaaccord
Jul 21, 2008 05:15 PM
