Problem with 2005 Accord A/C Blowing warm
Old Aug 27, 2016 | 09:04 AM
Brad Snyder's Avatar
Default Problem with 2005 Accord A/C Blowing warm
Hi there
i have an 05 accord coupe 3.0l v6
all of a sudden the air started blowing warm.So i started poking around.Its NOT the relays and there is 14volts to the coil........What happens is on a cold start the clutch will engage and blow cold for about 2 minutes then the clutch kicks off and stops spinning therefore blowing warm air.....The rest of the day the clutch will not engage,but as soon as i let it sit overnight it will engage for about 2 minutes before kicking off for the day......What do you think this is???Clutch?Coil?or both?
thanks for the help
Old Aug 31, 2016 | 05:25 AM
welcome to the forum. Possible freon low.
Russ Ware
Aug 8, 2013 08:56 AM
ScottDuVall
Jan 27, 2010 02:15 AM
gonzo6580
Nov 19, 2009 09:40 PM
Isporthonda
Jan 21, 2008 03:22 PM
mraquarius
Apr 25, 2007 01:33 PM
