Problem with the petrol gauge
Old Mar 19, 2013 | 07:17 PM
Still learning's Avatar
Default Problem with the petrol gauge
Hi everyone,
My wife put to much gas in the tank of our 2007 Honda Civic. Since that time the petrol gauge remain full.
Is there something, I can do?
Thanks
Old Mar 19, 2013 | 07:27 PM
lowlife9's Avatar
you can't really put to much gas in a gas tank that wouldn't cause a problem. so either its the gauge itself or maybe the float in the gas tank. try using a fuel cleaner and see if that works maybe some Seafoam brand . or gain access to the float in the tank.
Old Mar 19, 2013 | 07:49 PM
So you're sure that the problem is related to the fact that my wife put to much gaz in the tank?
Do you know, if it cost a lot to repair. I have no talent in mecanics... If so how much do you think it's going to cost me.
Thanks
Old Mar 20, 2013 | 05:02 AM
welcome to the forum. if it is the float, the cost is approx 150.00 plus the fuel tank usually needs to be dropped to r & r the float. takes approx 3.5 hrs to drop and reinstall the tank ( est ) Honda labor is about80 to 120.00 per hr depending on dealership. Find a good shop AAA rated and get some estimates. filling up the tank max does not make the float stick.
Old Mar 20, 2013 | 07:31 PM
lowlife9's Avatar
if its setup like a civic i don't believe you have to drop the tank. you gain access to the fuel pump and float via under the backseat but i could be mistaken.
Old Mar 21, 2013 | 06:38 AM
you may be correct lowlife9. last one I worked on was a 90 accord. i did gain access from the back of the back seat.
Old Mar 26, 2013 | 07:34 PM
lowlife9's Avatar
just found this thought it could help http://www.civicforums.com/forums/3-...ding-unit.html
norddal
May 18, 2014 02:18 PM
sathya
Jun 6, 2010 10:28 AM
delphini
Nov 1, 2009 05:41 AM
scott1ct
May 21, 2007 11:22 AM
phyl26
May 8, 2007 06:42 AM
