Pulsating noise in rear wheels
Old Jul 11, 2016 | 02:50 PM
mcfur's Avatar
Default Pulsating noise in rear wheels
Hello everyone,
I had my Honda element sitting outside unmoved for about 2 months. Immediately before this I replaced the brake pads, resurfaced the rotors, had an alignment, wheels balanced, and changed all fluids. I took it for a drive today and the rear wheels (possible only 1 of them) are making a screeching/ pulsating noise and are causing a slight vibration. I assumed it was rust buildup on the rotors so I drove it around a parking lot for about 15 laps and applying the brakes after building up a little speed. The pulsating/screeching noise is becoming more quiet, but it is difficult to say if the vibration from the pulsing is also reducing. Should I keep driving it and see if it goes away or take it to get inspected?
Old Jul 12, 2016 | 08:51 AM
mcfur's Avatar
Just had the brakes inspected by Honda and everything is okay. Not sure what else may be causing this issue.
Old Jul 12, 2016 | 07:11 PM
Sometimes when a car sits for a period of time the tires become temporarily out of round,they developed a flat spot,that may be what you were feeling.
Old Jul 15, 2016 | 05:59 PM
lowlife9's Avatar
vibrations could be caused by a bad wheel bearing or the tires may not have been balanced properly or a wheel weight could have fallen off. try swapping the rear tire to the front and see if vibrates the front.
tunis
Sep 21, 2009 08:27 PM
poppies18
Apr 14, 2009 03:13 PM
madvibes
Aug 10, 2007 11:03 PM
TREK 9.8
Apr 19, 2007 12:39 PM
NSOMNIACconcepts
Jan 19, 2006 05:43 PM
