shaking problem... rotors maybe?
Old Aug 17, 2012 | 01:42 PM
wisemanhonda's Avatar
Cool shaking problem... rotors maybe?
I have a gut feeling that my front brake rotors are messed up. My '03 Accord shakes a good bit at all speeds. My steering wheel tugs and shakes to accompany the vibrations I feel while driving. Can anybody provide me with some insight?
Thanks
Old Aug 17, 2012 | 01:56 PM
welcome in, Car shaking problems are usually the results of mechanical problems. Bent rims,out of balance tires ,or suspension out of adjustment will make the car shake after reaching a certain speed. Warped brake rotors will also make the car shake when it’s slowing down. Also check your lug nut and make sure they are tight.
Old Aug 17, 2012 | 02:02 PM
Yea, she shakes moreso while driving/accelerating rather than while depressing on the brake pedal. Can you provide me a ballpark repair cost on those mechanical problems you mentioned?
Thank you
Old Aug 17, 2012 | 07:16 PM
lowlife9's Avatar
the wheel weight probably fell off have your tires balanced it won't cost much especially if you remove the tires yourself.
Old Aug 17, 2012 | 09:52 PM
awesome, thank you for your insight.
Old Sep 5, 2013 | 07:32 PM
mfuji55's Avatar
Default steering wheel vibrates when braking
check out this video i made. I think it is the rotors:
mike0094
Aug 5, 2010 02:58 AM
UEDan
Jun 4, 2010 02:25 AM
97CL3.0
Jan 31, 2010 02:01 PM
COYOTE102076
Apr 21, 2008 06:08 PM
kip0485
Apr 8, 2008 12:07 AM
