Speed Sensor Issue
Old Jul 7, 2019 | 02:40 PM
Hondaindy209's Avatar
Default Speed Sensor Issue
Hey there, I just replaced the clutch in my 2015 Accord EX 6-speed. It drives and shifts smoothly so everything is usable, but a few things are not working properly after I put everything back together.
First, my speedometer is not working. During the process of taking out my hubs I took out the speed sensors that stick into the hub. I made sure to put them back in and I didn’t stress the wires that were connected to the sensor at any time. It seems simple enough but is there something I needed to do to properly reinsert them or should I just buy new sensors...?
Second, when I was driving prior to the clutch change, if I drove fast enough, my shifter wouldn’t allow me to move into reverse. Now, I can be on the freeway going 65 and I can put it in position to pull it into reverse which freaks me out because it would be really easy to accidentally shift into reverse instead of 6th. Did I loosen something I need to tighten when I changed my clutch or can someone tell me if this is a product of the speed sensor not working as well?
Any information is appreciated
Old Jul 13, 2019 | 07:03 PM
Did you find out what was wrong?
Wheel speed sensor should be for the ABS system and not for the speedometer.
There should be a line from the transmission that does that.
Would go over what was done during the clutch change and see if something was put back or torn out.
rabbithutch
Dec 16, 2010 02:42 PM
tranquildisorder
Oct 6, 2009 03:05 PM
Donkeydawn11
Sep 10, 2009 02:26 AM
