SRS Warning Light Stays On
Old Aug 14, 2009 | 09:52 AM
paulpatter's Avatar
Default SRS Warning Light Stays On
I have an '01 Honda Civic. Recently I had to remove the front passenger seat to accommodate a large package. In removing the seat, I had to disconnect what I assume is part of the wiring for the SRS system. When I re-installed the seat, I THOUGHT I reconnected the wires correctly (by joining the two plastic clips). However, now the SRS warning light stays on. Is this the kind of problem that needs the attention of an expert? (BTW, the owner's manual--which I read after the fact--says, in effect, "Don't mess with SRS wiring!") I should add that I disconnected the battery before disconnecting the wiring.
I will value and appreciate your counsel.
Paul
Old Aug 15, 2009 | 07:00 AM
welcome to the forum. Note: Disconnecting the battery will not help. try this site to get the info you need.
http://www.civicforums.com/forums/36...ease-read.html
Hope this works
Old Aug 15, 2009 | 04:57 PM
paulpatter's Avatar
achmech52: All right! The procedure described in the link you provided worked like a charm--on my first try!
Many thanks!
Paul
Old Sep 1, 2009 | 06:38 AM
smithteddy123's Avatar
as far as my opinion is asked yes you should go and consult the experts as any kind of odd thing happening to your vehicle is not a good sign.
Honda48
May 27, 2018 10:09 PM
Dwayne Robertson
Jul 3, 2015 09:01 AM
Ted Zagurski
Jan 22, 2011 12:14 PM
Marc
Nov 22, 2008 06:05 AM
dgresham2134
Apr 18, 2008 12:12 AM
