tech help plss
Old Jun 8, 2007 | 07:09 AM
theuniqueartist's Avatar
Default tech help plss
I have a problem and i think its big ;(.. well i got those fuel injectors from ebay for my del sol.. they didnt go in eassy and the plugs were a lil different but after a litle modification i was able to plug the new injectors and run the car.. the car was actualy running for 2 days.. and than it just stoped.. now when i turn the keys on i dont get anypower on my gauges or anything.. i mean the CD works and some lights for the heater but noting on the gauges i dont get the batery ot the engine light .. i got a new battery and i checked all the fuses but nothing.. sometimes..some of those lights starts blinking for a lil bit and if makes some kliking noise from where the fuses are udner the dash board but thats it.. still nothing.. is it the computer or what do i have to go after? i guess i will try to put my old incetors but its too late now.. its something alse.. thanks for the help!
Old Jun 13, 2007 | 06:40 PM
a_l_e_x1's Avatar
Default RE: tech help plss
The thihng about injectors is if they aren't the right ype, you can fry your computer. They have a coil inside (same as a solenoid) and when you put voltage across it, it creates an electromagnetic field and makes the injector open/close. If that coil is of the wrong type (lower resistance), then the controlling circuit of the computer will burn. I guess it only lasted for 2 days.
Try to take them off (the injectors that is) and make the engine turn (won't start the engine for obvious reason ).
Please specify your car model/year/transmission.
Turn the inside light on and try to crank the engine. If the light goes dimmer, then the power is going to the starter motor. If not, then post back here and I'll try to help you.
Old Jun 13, 2007 | 06:41 PM
a_l_e_x1's Avatar
*nothing*
Dlygamtrupfar
Jan 22, 2010 01:42 AM
poetntheprocess
Sep 6, 2008 07:51 PM
lethallykreated1
Nov 26, 2007 10:02 AM
drunkenmunkey
Jun 5, 2007 11:10 AM
drunkenmunkey
Jun 5, 2007 11:01 AM
