Timing Belt & Water Pump Info - New Member
Old Feb 17, 2012 | 07:38 AM
scurling's Avatar
Default Timing Belt & Water Pump Info - New Member
I'm considering the purchase of a low milieage Honda (Accord or Civic , 2002 to 2006). I'm looking for some general info on the timing belt and water pump replacement. Let me first say, my last Honda was a 1978 Accord. I've been a GM or Ford owner ever since. I try to do most of my auto maintenance and repair possible, as time and ability allow.
So that said, I hear the timing belt and water pump replacement are crucial around 80 to 100k miles. Is this a job that many people perform on their own in the garage/driveway, or is it strictly a repair shop job?
I haven't found or settled of a specific year and model Honda, but was hoping to use this maintenance requirment as a price negociating tool to lower the purchase price a little if the work had not already been done.
Also, any tips on which year model has benefits over others in this area (belt & water pump) would be greatly appreciated.
thanks,
Stan
Old Feb 17, 2012 | 08:29 AM
Donkeydawn11's Avatar
Default timming and water pump replacment
Hi seen you post I did mine a few months ago for the 1st time I was hesitent but I just did a search on you tube and found a number of vids on how to do it and it was exactly as they showed it no problem at all no special tools. The only thing was have a air gun handy to remove the main drive pulley nut and spray it a couple of times with PB blaster a few days before you take it off it can be hard to remove that was the worse part of the job everything else is down hill
It the nut wont come off heat with a torch and lots of PB blaster
if you need any more help just email me
Hope this helped
Old Feb 17, 2012 | 08:35 AM
scurling's Avatar
Thanks, that's the type of info I was looking for. I do have a number of shop (garage) tools,w/air impact wrenches. I've replaced timing chains and gears on Buick V-6 and Chevy V-8s, so I figured I had a good chance at doing the belt and w/p replacement myself.
Any tips on model years to keep away from while I look for a good buy?
Old Feb 20, 2012 | 09:18 PM
lowlife9's Avatar
2001-2003 civics have major automatic transmission problems the clutch packs chew themselves to pieces the 2004-2005 aren't as bad but they still have bugs
this should give you an idea about the timing belt DIY.
http://www.7thgenhonda.com/forum/showthread.php?t=22923
honda al
Mar 12, 2014 11:49 PM
forevermemorable
Sep 20, 2013 10:44 PM
Timmy77
Feb 25, 2013 06:30 PM
sandyg645
Oct 20, 2008 06:19 AM
vigorcomp
Jul 4, 2007 09:29 PM
