Timing Marks - K24 Accord
Old Nov 21, 2021 | 09:51 AM
HondaDude48's Avatar
Default Timing Marks - K24 Accord
Hello, I'm replacing a stretched timing chain. Everything seems to line up, except the colored link on the crankshaft. Any help would be appreciated
Old Nov 21, 2021 | 11:34 AM
Seems like you haven't pulled the pin on the tensioner??
If all the marks are lined up?? And you are sure about that then what could be wrong?
Old Nov 21, 2021 | 08:47 PM
Just concerned as to why the chain link isn't lining up on the crank like they're suppose to, it's almost like it's too tight. From what I've seen you should be able to line up the links with the marks effortlessly, mine refuses
Old Nov 22, 2021 | 08:44 AM
The k24 engine is an interference engine.
Be careful.
So, would slowly hand crank engine to see if the chain is on correctly
And nothing is hitting when it should not.
Crank should go around twice to make the check complete
Nov 22, 2008 08:38 PM
