Trans Fluid
Old Jun 25, 2015 | 08:33 AM
shhaskins's Avatar
Default Trans Fluid
I have a 09 civic and a 07 accord 4cyl. I am going to change the transmission fluid, how much fluid does each car hold? Very hard to see new fluid on dip stick.
Old Jun 25, 2015 | 07:35 PM
lowlife9's Avatar
automatic or manual ?? autos usually neeed around 2.5 quarts for a single drain and fill honda recommends you drain and fill 3 times to get all the old fluid out of the torque converter in total there's around 8~12 quarts of ATF in the trans and converter. your suppose to drive around for 15 minutes then shift from park to reverse between every drain and fill. if i was you i would buy a manual for each car.
Old Jun 26, 2015 | 02:53 AM
welcome to the forum use honda auto trans only no aftermarket unless you want to replace your auto trans in a short time.
papasloane
May 14, 2023 07:22 PM
donnief150
Apr 24, 2010 10:48 PM
triad67
Oct 20, 2008 04:50 PM
rodallg
Nov 26, 2006 10:09 PM
Razorbacksfan88
Nov 17, 2006 10:53 PM
