Unknown electric issue
Old Sep 28, 2020 | 03:12 PM
Brigham Robins's Avatar
Default Unknown electric issue
I have a 95 honda accord f22b 2.2L vtec, recently every now and then while driving the odometer and speedometer will start bouncing around and when turned off the car wont start or even turn electronics on. I tested alternator by removing a battery connection while car is on and running and the car stays on so I dont think the alt is bad, would this be a bad battery ?
Old Sep 28, 2020 | 07:10 PM
Welcome in, its very possible ,i had a truck once die on me like that and it was the battery. If you can swap it with another. Good luck.
Old Sep 28, 2020 | 07:11 PM
It is more likely that it is a wiring issue and probably one or more electrical components.
But, where to start looking??
Engine bay? Wiring looms and any place it can rub, or experience heat and vibration.
Fuse box itself? Looking for corrosion??
Old Sep 28, 2020 | 07:35 PM
I took it in for an answer and it turns out it is the alternator, its jist not completely dead yet. Thanks though for the responses
Old Sep 28, 2020 | 07:42 PM
thanks for the feed back. good find.
Mark Minks
Oct 21, 2019 04:04 PM
chigglebits
Nov 1, 2018 06:29 PM
Dblock802
Mar 6, 2014 12:24 PM
rkenyon4106
Oct 4, 2011 08:37 AM
artist118
Aug 29, 2006 12:31 PM
