Where is the OBD Connector on '93 Accord?
I need to locate the OBD connector for my '93 Accord SE. I have a CD with maintenance and repair information but it doesn't indicate where the "Integrated Control Unit" is located.
I believe that it is located under the dashboard on the passenger side somewhere in the vicinity of the glove box but I don't see anything there that looks promising. Anyone? TIA |
2 Attachment(s)
I'm having the same problem, trying to locate the OBD plug on my '93 Honda Accord but I'm not finding a blue plug with two wires as pictured on every site and YouTube video I've looked at. I've searched under the dash on both sides with no luck.
I have, however, found a yellow plug fastened to the chassis under the passenger side plastic kick plate (if this is the right way to describe it), to the right of where one finds the ECU and TCU. It has six brown wires and a hinged cover that conceals a socket for, I assume, attaching a scanner. I'd like to short the plug with a paper clip in order to read the code off the Engine Check light but have no clue as to how to proceed with this six-wired plug. Any suggestions? Am I looking in the wrong place? I've included photos of the plug if this will help. Thanks! |
