Where is the OBD Connector on '93 Accord?
Old Apr 23, 2016 | 05:16 PM
cueball21's Avatar
Member
Default Where is the OBD Connector on '93 Accord?
I need to locate the OBD connector for my '93 Accord SE. I have a CD with maintenance and repair information but it doesn't indicate where the "Integrated Control Unit" is located.
I believe that it is located under the dashboard on the passenger side somewhere in the vicinity of the glove box but I don't see anything there that looks promising.
Anyone?
TIA
Old Aug 3, 2016 | 12:59 PM
Gorillamo's Avatar
I'm having the same problem, trying to locate the OBD plug on my '93 Honda Accord but I'm not finding a blue plug with two wires as pictured on every site and YouTube video I've looked at. I've searched under the dash on both sides with no luck.
I have, however, found a yellow plug fastened to the chassis under the passenger side plastic kick plate (if this is the right way to describe it), to the right of where one finds the ECU and TCU.
It has six brown wires and a hinged cover that conceals a socket for, I assume, attaching a scanner. I'd like to short the plug with a paper clip in order to read the code off the Engine Check light but have no clue as to how to proceed with this six-wired plug. Any suggestions? Am I looking in the wrong place?
I've included photos of the plug if this will help.
Thanks!
Attached Thumbnails Where is the OBD Connector on '93 Accord?-plug-wires.jpg   Where is the OBD Connector on '93 Accord?-plug-end.jpg
serhey778
Nov 24, 2015 09:31 AM
rdriscoll36
Jun 26, 2013 05:42 PM
mmgehrig
Sep 1, 2010 05:22 AM
civicracer1997
Nov 26, 2007 08:57 PM
civicracer1997
Nov 26, 2007 08:53 PM
