01 accord transmission problem
Old Jul 10, 2010 | 10:29 AM
manderson24's Avatar
Default 01 accord transmission problem
my 01 accord acts like the tranny slips between first and second gears as the engine rpm's climbs considerably when shifting between those gears. Any suggestions would be appreciated.
Old Jul 15, 2010 | 05:43 AM
not much info on your 01 accord, so guessing at it. torque converter may be going bad, common problem with 2000 up accords. go to HondaProblems.com and go to the transmission section, it will show you what you might do to get help from Honda. also check all your solinoids for cleaness.
or you can change the trans fluid using honda fluid only, no additives and see if this helps. if the car is used, the previous person or non honda dealer could have put in a chemical trans no slip. this is a no no.
Old Jul 16, 2010 | 11:37 AM
I had problems with the tranny in my 2000, flushed it and has been working fine.
mike0094
Jan 8, 2009 04:24 AM
jksharp
Dec 2, 2008 10:33 AM
scasper
Sep 30, 2008 10:34 PM
Nekro
Dec 6, 2006 02:38 PM
cosmo
Aug 2, 2006 01:47 AM
