02 accord wont start
Old Aug 1, 2023 | 05:01 PM
veil's Avatar
Default 02 accord wont start
after i changed the ignition coils the car didn't want to start .it has been drivin yesterday with cylinder 3&4 miss fires thinking changing ignition coils was gonna fix the problem . now it barely even starts jus shaking the car no start i have i didn't install the coils correctly
Old Aug 1, 2023 | 06:57 PM
welcome to the forum. Try putting the old ignition coils back on and check your spark plugs.
Old Aug 1, 2023 | 07:09 PM
veil's Avatar
i installed iridium plugs idk if that might be it . i tried putting the old ones back alr . while trying to start it little smoke started forming .checked the plugs they looked fine
Old Aug 1, 2023 | 08:43 PM
Where was the smoke?
Old Aug 1, 2023 | 09:10 PM
veil's Avatar
i saw it from the oxygen sensor from the manifold
Well, I do not remember if the coils are COP or just a set on distributor.
If you put everything back to original parts then it should go back to original condition
Unless, something else failed???
In any case, back to basics, check the spark with the plug pulled out
Check to see if the injectors have control pulses and see if the fuel pump runs, etc
Old Aug 2, 2023 | 09:31 AM
Follow the smoke to the wiring problem. You have a ground attached to a power.
Jdemery89
Aug 16, 2021 10:52 AM
Angelica Rivera
Apr 26, 2021 07:04 AM
klaj2k
May 11, 2016 03:17 PM
santiago
Sep 1, 2010 07:40 PM
cyntherian
Jun 26, 2007 03:10 AM
