03 Honda accord v6
Old Jun 23, 2025 | 01:40 PM
Brian204's Avatar
Default 03 Honda accord v6
I have a 2003 Honda accord but been having transmission problems 2nd and 3rd gear arnt shifting properly sometimes they do sometimes they don’t and everytime I put the car into reverse the engine jerks does anybody know what would cause this???
Old Jun 23, 2025 | 04:09 PM
Try a bottle or can of trans fix.
Old Jun 23, 2025 | 08:37 PM
Brian204's Avatar
I have tried that and it did nothing seems like it got worse after
Old Jun 23, 2025 | 08:41 PM
Do you have a pressure gauge?
Old Jun 23, 2025 | 08:43 PM
Brian204's Avatar
Unfortunately I don’t but the code that came up when I scanned the car was p0741 which is torque converter clutch solenoid circuit performance stuck off it says do you know what that means? I’m new to Honda so I’m just learning
Old Jun 23, 2025 | 09:13 PM
You may need help with this. The entire manual for your car is in here.
Operation CHARM: Car repair manuals for everyone.
Home >> Honda >> 2003 >> Accord V6-3.0L >> Repair and Diagnosis >> A L L Diagnostic Trouble Codes ( DTC ) >> Testing and Inspection >> P Code Charts >> P0741
P0741
DTC P0741: Torque Converter Clutch Circuit Stuck OFF
NOTE: Record all freeze data and review General Troubleshooting Information before you troubleshoot.
1. Warm up the engine to normal operating temperature (the radiator fan comes on).
2. Check to be sure that the transmission is filled to the proper level, and check for fluid leaks.
3. Drain the ATF through a strainer. Inspect the ATF and strainer for metal debris or burnt fluid.
Has the ATF deteriorated?
YES-Replace ATF, and test-drive the vehicle under the same conditions as those indicated by the freeze data, then recheck.
NO-Go to step 4.
4. Clear the DTC with the HDS.
5. Select LOCKUP SOL TEST in MISC. TEST MENU, then carry out A/T LOCKUP SOL A test in LOCKUP SOL TEST MENU with the HDS.
Is a clicking sound heard?
YES-Go to step 6.
NO-Replace torque converter clutch solenoid valve, then go to step 10.
6. Select LINEAR SOL TEST in MISC. TEST MENU, then carry out LINEAR SOL C TEST in LINEAR SOL TEST MENU.
Is the system OK?
YES-Go to step 7.
NO-Follow instructions indicated on the HDS by the tester result. Go to step 10 if any part was replaced.
7. Run the engine until the engine coolant temperature reaches 176°F (80°C).
8. Test-drive the vehicle at 55 mph (88 km/h) for 2 minutes while monitoring the vehicle speed with the HDS.
9. Check the OBD Status in DTC Monitor Tool from DTCs/Freeze Data in A/T Mode Menu for a pass/fail test of code P0741.
Did the result indicate a fail?
YES-Repair the faulty torque converter clutch mechanism, torque converter clutch hydraulic circuit, lock-up shift valve, or lock-up control valve, or replace the transmission.
NO-Intermittent failure, the system is OK at this time. If the tester indicates NOT COMPLETE, return to step 8 and recheck.
10. Clear the DTC with the HDS.
11. Test-drive the vehicle for several minutes under the same conditions as those indicated by the freeze data.
12. Check the OBD Status in DTC Monitor Tool from DTCs/Freeze Data in A/T Mode Menu for a pass/fail test of code P0741.
Did the result indicate a pass?
YES-The problem has been corrected.
NO-Return to step 1 and recheck.
pro multis · About Operation CHARM
bleak
May 7, 2021 01:05 PM
Duck95
Jun 8, 2014 11:40 AM
03v6accord
Mar 1, 2010 08:39 AM
thunderstorms42
Aug 29, 2008 10:24 AM
okieray
Feb 1, 2007 02:10 AM
