1988, 2014 Accord won't start in Park
Old Oct 24, 2022 | 05:27 PM
KenE's Avatar
Default 1988, 2014 Accord won't start in Park
re: 2014 Accord sedan base mdl
It would not start in Park. We recalled this happening to a 1988 Accord sedan.
With the '88, we shifted to neutral and sometimes back to Park & then it started.
With the '88, there was some kind of washer-type thing on a shaft that was not moving properly.
I think this must be a similar problem, but I don't remember what it was called, etc.
(Yes, the battery was new this year.)
Any thoughts?
Old Oct 24, 2022 | 10:14 PM
Need to check the range switch. Do you have a capable scan tool?
Old Oct 29, 2022 | 11:51 PM
KenE's Avatar
No scan tool. Range switch sounds like a good place to start.
Old Oct 30, 2022 | 01:27 PM
There's a way to adjust the shift cable using a 6mm pin. You have to take the center consul off.
I can see if I can get the info.
Old Dec 1, 2022 | 08:34 PM
KenE's Avatar
We found the problem to be the starter.
Range switch seemed to be okay.
But thank you for the suggestion.
Jdemery89
Aug 16, 2021 10:52 AM
slmilde
Mar 10, 2020 11:54 PM
millertimegooney
Mar 28, 2016 11:11 AM
trev0006
Aug 19, 2013 01:35 PM
