1992 accord wagon
1992 accord wagon
HELLO OUT THERE TO ALL, LOOKING FOR A LITTLE HELP, MY 92 ACCORD WAGON BROKE THE TIMING BELT ON THE HIGHWAY AND OF COURSE SHUT OFF, GOT IT HOME AND STARTING TODISSASEMBLE FOR THETIMING BELT CHANGE, MY QUESTION IS DO YOU THINK I HURT THE VALVES? IT MADE NO NOISES, THE CAR HAS 190000, MILES RUNS LIKE A TOP. ANY ADVICE WOULD BE GREAT, AND ALSO WHAT BRAND BELTS TO GET. THANK YOU ALL IN ADVANCE..
RE: 1992 accord wagon
welcome to the forum, purchase Honda timing belt, water pump and seal, cam seal, crank seal. while you are replacing the timing belt,the water pump and cam and crank seals are all there. Don't want a water leak a few thousands miles down the line nor oil leak on the driveway.
Might be a good idea to do a compression check before you start the engine. the accord has a 0 tolerance for broken timing belt. If all compression is good, no valve bent or dropped,
or hole in the piston.
Just for info, you are writing in allcapitol letters, means you are shouting oryelling your message to us all.
