1994 accord will not start in the heat
i have a 1994 accord that starts fine when is cool outside ...but when it hot it will not start til it cools ..it just turns and turns just started this when it got hott outside ... help me please ..
welcome to the forum. check your main relay, ignitor/coil,distributor.
mine did that...had a broken wire at the distributor wire plug
Originally Posted by cord92
(Post 13267)
mine did that......... is main relay of fuel pump |
I have had starters in two different cars refuse to work when hot,if everything else turns out not to be the problem ,swap starters. Or at least try a heat shield,you didn't by chance just put a header on that car did you?
You should check your main relay, ignitor/coil,distributor.It's good
_________________ poker bonus Boxing Betting |
