1994 accord will not start in the heat
Old Jun 3, 2010 | 05:52 AM
cord92's Avatar
Default 1994 accord will not start in the heat
i have a 1994 accord that starts fine when is cool outside ...but when it hot it will not start til it cools ..it just turns and turns just started this when it got hott outside ... help me please ..
Old Jun 3, 2010 | 11:39 AM
welcome to the forum. check your main relay, ignitor/coil,distributor.
Old Jun 10, 2010 | 09:10 PM
tonkkids's Avatar
mine did that...had a broken wire at the distributor wire plug
Old Jun 11, 2010 | 09:21 AM
altn's Avatar
mine did that......... is main relay of fuel pump
Old Jun 11, 2010 | 11:55 AM
I have had starters in two different cars refuse to work when hot,if everything else turns out not to be the problem ,swap starters. Or at least try a heat shield,you didn't by chance just put a header on that car did you?
Old Jun 11, 2010 | 01:31 PM
kosovohp's Avatar
You should check your main relay, ignitor/coil,distributor.It's good
_________________
poker bonus
Boxing Betting
flogger157
Mar 22, 2015 07:34 AM
minibutton
Jul 8, 2011 01:10 PM
masduud
Jun 23, 2010 11:37 AM
Donkeydawn11
Jan 27, 2010 03:35 AM
