1994 vtech accord ex with knock noise
Old Sep 21, 2010 | 01:07 PM
Donkeydawn11's Avatar
Default 1994 vtech accord ex with knock noise
Hi everyone can any one tell me what sound this is and the fix
Thanks
http://www.youtube.com/watch?v=bKDaUb5nzCg
Old Sep 22, 2010 | 03:19 AM
If you have high milage, it sounds like a possible rod knock. have you ever had the valves adjusted? what viscosity oil are you using? Has the engine ever been overheated? The fix for a rod knock is overhaul (if that is what the sound is from)
Old Sep 22, 2010 | 12:17 PM
Thanks for the response
im using gtx high mileage 5W 30
the engine has not overheated but then again I have had it for about 1 yr now. I have had the valves adjusted
Would you recommend putting Synthetic oil 5W 30 along with some valve treatment oil.
Old Sep 23, 2010 | 03:48 AM
won't make much of a difference what type of oil is used to get rid of the noise, synthetic will not hurt the engine, just expensive good oil being used. how long has this noise been with the engine, or when did it start. normally the noise will go quiet when the engine is working to push the car forward. when you cruise, it will make more noise. (rod knock) what is the milage of the engine.
Honda Accord
Jun 22, 2013 05:07 AM
GStevison
Sep 2, 2009 12:39 AM
JJJeff
Aug 27, 2008 09:26 PM
cgb5208
Mar 28, 2007 11:34 PM
cgb5208
Feb 1, 2007 11:15 PM
