1998 Accord Coupe Climate Control Issue
Old Mar 12, 2016 | 09:12 PM
ablevins31's Avatar
Unhappy 1998 Accord Coupe Climate Control Issue
My '98 Accord only blows out blistering hot air and only to defrost. I cannot not adjust the temp or change the air output location. The fan control works so i can turn that off, but hot air still comes through. Below are the things i have tried:
  • I have manually moved the control to the heat control valve that stops hot coolant from flowing into heater core.
  • I have verified the appropriate fuses are ok.
  • I tried and failed to clamp shut the small coolant hose that goes into the heater core.
What are some things i can try? Are there any control levers or manual mechanism that i can adjust to cold for the summer? Is there any electrical parts that commonly fail causing my issue?
thanks for any advice!
Old Mar 13, 2016 | 04:15 AM
ablevins31's Avatar
Update: I have discovered that the climate control panel is faulty. I also learned that manually closing the heater control valve by hand is tricky to know you are completely closed.
Take 2 on the bypass was a success, i forgot to burp the cooling system first time round. I am going to just leave it bypassed for now.
Old Mar 14, 2016 | 07:21 AM
fastlane's Avatar
Member
Wow that was fast. Good thing you have fixed the issue by yourself.
benboy12
Jan 17, 2012 07:39 AM
Robks
Apr 29, 2009 04:19 AM
suzy fisher
Apr 23, 2009 12:16 PM
jeffle
Apr 7, 2007 09:22 PM
PW01
Aug 1, 2006 04:13 PM
