2000 Honda Accord
Old Jan 22, 2018 | 02:39 PM
Joker2018's Avatar
Default 2000 Honda Accord
Is there anyway to tell if head assembly is cracked.Also,Head gasket is blowed.
Old Jan 23, 2018 | 02:39 AM
head gasket blown can be found by taking a compression check, there will be no compression or very low compression if the head gasket is blown. also need to be sure there is no air leaking through a bad valve intake or exhaust. another way to know if a head gasket is blown or crack head or block is water in the oil, or lots of air coming out of the radiator or overheating. sometimes if the valve cover is removed and engine running ( not always reccomended ) you can see air bubbles on the head if cracked. I've seen all the above. if the engine is still together, need more input of what is happening to get a better idea of a failure.
Old Jan 23, 2018 | 08:34 AM
Also you may see white smoke or steam coming from the exhaust pipe.
Old Feb 26, 2018 | 07:35 AM
hichamaziz's Avatar
misterix
Mar 13, 2009 04:24 AM
ODUB
Mar 7, 2009 06:52 AM
jfernandez1977
Aug 12, 2008 11:53 PM
RotarySoldier
Jul 22, 2006 05:59 PM
CindyNg
Jun 27, 2006 01:18 PM
